idontcare67's avatar
Jul 16, 2020
Access control has no effect on Orbi RBK853
System is set up and working fine except that devices that are blocked via web site or app continue to have Internet access.   Using most recent firmware available through app update (haven't insta...
  • idontcare67's avatar
    idontcare67
    Jul 16, 2020
    Thanks for the reply.
    I reached out to support and based on their advice installed a new hotfix firmware, reset my system to factory defaults and now it works as expected.
    A bit of a pain in the b#@t but at least it fixed the problem.
