Nobber1066's avatar
Nobber1066
Access Denied Help Please
Hello I have Orbi RBE960 and two satellites updated to Firmware Version V7.2.6.21_5.0.20 tonight I have started to get access denied on some websites example Access Denied You don't have permiss...
  • FURRYe38's avatar
    Sep 11, 2023
    Is this happening across all devices?
    Do you have Armor or Smart Parental Controls enabled with in the Orbi mobile app at all?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
