vtburtonra's avatar
vtburtonra
access the list of attached devices via URL with json output
I have an Orbi RBR850 and two RBS850's.  In combination, they provide excellent WiFi coverage to my house.  The RBS's are connected back to the RBR via Ethernet.  I have "a bunch" of IOT devices conn...
  • vtburtonra's avatar
    vtburtonra
    Feb 16, 2023
    CrimpOn wrote:
    I found the READ.ME less helpful than I would have wanted, especially in terms of how to enter the commands.
    Plus, it spewed a bunch of warnings about "certificate verification" which did not affect the results, but annoyed me a lot.
    Loaded on Linux Mint 20.3 using pip3.
    Set environment variables:
    PYNETGEAR_PASSWORD="<router password>"
    HOST=192.168.1.1
    USER="admin"
    URL="192.168.1.1"
    command python3 -m pynetgear_enhanced attached_devices2 >dev.txt
    I got it to work, but had to do this:
    python3 -m pynetgear_enhanced --url 'https://routerlogin.net' --host "192.168.1.1" --user "admin" --password "<router password>" attached_devices2 >dev.txt 2>&1
    The https in the URL did the trick.  It did not seem to pay attention to the PYNETGEAR_PASSWORD, HOST, USER and URL variables.  I tried setting them within a bash script and also exporting them.  The command worked for me on OpenSUSE, Ubuntu, Fedora, Mint, Rasbian, and Debian.
    This uncovered another problem.  I have an RBR850 and two RBS850s.  When I log into the RBR, and go to attached devices, it only shows 1 device from one of the two RBSs, but that RBS has 10 devices attached to it.  When I log into the RBS directly, and select Connected Devices, it shows all 10 devices, but the IP address field is "-" for all except 1 device, and that's the 1 device that shows up in the RBR.   The pynetgear_ehnanced program shows the same, but expected given that logging directly into the RBB shows this.
    The other RBS shows everything correctly, including IP addresses.  All 3 are running the latest firmware (4.6.14.3).
    Note that all 10 of those devices are working fine - I can ping them.  Even pinging them doesn't cause the RBS to start showing their IP addresses.  I'm guessing this RBS is fubar and needs a reboot.  I'll do that and I'm assuming that will fix it.
    I really do appreciate your help and suggestions on this.
    Randy
