vtburtonra
Feb 14, 2023Aspirant
access the list of attached devices via URL with json output
I have an Orbi RBR850 and two RBS850's. In combination, they provide excellent WiFi coverage to my house. The RBS's are connected back to the RBR via Ethernet. I have "a bunch" of IOT devices conn...
- Feb 16, 2023
CrimpOn wrote:I found the READ.ME less helpful than I would have wanted, especially in terms of how to enter the commands.
Plus, it spewed a bunch of warnings about "certificate verification" which did not affect the results, but annoyed me a lot.
Loaded on Linux Mint 20.3 using pip3.
Set environment variables:
PYNETGEAR_PASSWORD="<router password>"
HOST=192.168.1.1
USER="admin"
URL="192.168.1.1"
command python3 -m pynetgear_enhanced attached_devices2 >dev.txt
I got it to work, but had to do this:
python3 -m pynetgear_enhanced --url 'https://routerlogin.net' --host "192.168.1.1" --user "admin" --password "<router password>" attached_devices2 >dev.txt 2>&1
The https in the URL did the trick. It did not seem to pay attention to the PYNETGEAR_PASSWORD, HOST, USER and URL variables. I tried setting them within a bash script and also exporting them. The command worked for me on OpenSUSE, Ubuntu, Fedora, Mint, Rasbian, and Debian.
This uncovered another problem. I have an RBR850 and two RBS850s. When I log into the RBR, and go to attached devices, it only shows 1 device from one of the two RBSs, but that RBS has 10 devices attached to it. When I log into the RBS directly, and select Connected Devices, it shows all 10 devices, but the IP address field is "-" for all except 1 device, and that's the 1 device that shows up in the RBR. The pynetgear_ehnanced program shows the same, but expected given that logging directly into the RBB shows this.
The other RBS shows everything correctly, including IP addresses. All 3 are running the latest firmware (4.6.14.3).
Note that all 10 of those devices are working fine - I can ping them. Even pinging them doesn't cause the RBS to start showing their IP addresses. I'm guessing this RBS is fubar and needs a reboot. I'll do that and I'm assuming that will fix it.
I really do appreciate your help and suggestions on this.
Randy
CrimpOn
Feb 14, 2023Guru - Experienced User
If you have Excel, you may find the commands you want in this spreadsheet:
https://www.dropbox.com/s/o0eaj5kjs3cpxcc/ORBI Soap Request.xlsm?dl=0
