Flupke's avatar
Flupke
Apprentice
Jun 09, 2022
Accessing router console from remote
I am currently facing network attacks towards my NAS. Luckily with little change to succeed given my NAS security configuration but still I would like to stop the traffic at port level, by disabling a URL mapping I had configured on the router (RBR850 v4.6.3.16 as far as I know not affected by the recent firmware issue: I never had a problem to access the console when on LAN).
The issue is that I am not on site and would like to do my configuration change remotely.
But I don't find a way to do so:
1/ the Netgear Orbi app does not allow to access the advanced configuration parameters and I don't find any way to manage ports using it
2/ the VPN connection to my LAN (managed using OpenVPN on the router) allows me to have a network connectivity to the router from my iPhone. The HTTP basich authentication pops up ...but systematically redirect me to the page only allowing to reset the admin password 😞 (http://{router-ip}/MNU_access_setRecovery_index.htm) rather than the administration page for the router
Isn't there anyway to access port mapping configuration without being on-site physically connected to the LAN?
  • FURRYe38's avatar
    Have a PC at the site and use a remote app like Remote Desktop or Teamviewer to control the routers web page thru the PC. Or you'll have to be on site.
    • Flupke's avatar
      Flupke
      Apprentice
      Thanks FURRYe38 .
      It confirms there is a need to be on the LAN to configure advanced parameters and that remote management of the router is barely for high-level parameters.
      I will probably not go for the complexity of having a remote desktop just for that purpose.
      I am still surprised that the "VPN" access is not working to access the console (VPN is imho seamless for the router: it should be as a machine on the LAN ...except if the router itself is doing the VPN - which it is doing in my case - and take "internally" into account the knowledge about the VPN-ization to filter accesses to console)
      • Flupke's avatar
        Flupke
        Apprentice
        I am facing a similar issue today while attempting to access the router remotely (through OpenVPN).
        At this stage I am still convinced it is due to my remote connection (the VPN being handled by the router, it may be treated in a special way) as I had usually no problem to connect to the console when on the LAN. And I didn't do any recent firwware upgrade so I don't see why it would suddenly stop functioning. But now reading your post I am a bit worried that I could have the same issue than you do. To be confirmed when I'll be back at home.
