Karen_mckenzie
Jul 31, 2020Follower
Acer chromebook won't connect to wifi
I just purchased and set up the Orbi 6 from Costco. Everything connected perfectly (screaming fast speed) except for my Acer Chromebook. It sees the Orbi, but when I try to connect I get this error...
Aug 04, 2020Guru - Experienced User
Any progress on this?
What happens if you disable AX Mode?
Try setting CTS to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Karen_mckenzie wrote:I just purchased and set up the Orbi 6 from Costco. Everything connected perfectly (screaming fast speed) except for my Acer Chromebook. It sees the Orbi, but when I try to connect I get this error: "Failed to connect to network ORBIXX: Unrecognized error: no-associated."
Help!
