yik1997hk's avatar
yik1997hk
Acess Control function is disabled
Hardware Version RBR750
Firmware Version V4.6.14.3_2.3.12
Hi all,
I wanna block some devices from using my network, and follow the instruction:
Select ADVANCED > Security > Access Control.
But the Security in the router's network does't work. When I open up Security, it has shown "Access Control" , " Bloacked Sites" and "Blocked Services",but I can't click any of them at all.
Has anyone experienced this issue? How to fix it?
Thanks all.
