Gielodaddy
Sep 15, 2020Star
ADC-V723 alarm.com webcams won't stay connected to my Orbi RBR850
I have a series of ADC-V723 cameras. They'll connect to the Orbi network, but then drop off frequently and intermediately come back on - finally just staying off. I've turned off 20/40 MHz co-exi...
betona
Mar 13, 2021Apprentice
I found this thread by Googling. It's not the same unit, but it is the same behavior and it worked a year an a half on 3 different Xfinity wifi access points.. I recently replaced that access point with the cable modem CBK752 kit which has the CBR750 access point and the RBS750 satellite. Everything else connected fine including other IOT devices, but I can't get the outdoor cam to connect at all. I also have the indoor V522IR cam and it never skipped a beat (same wifi login/pwd).
I called support and alarm.com decided the wifi had failed in the cam so they sent me a new one. It won't connect either. When you load that little web page from the camera to give it the login, it shows a signal strength and mine's around 88 which is plenty. I moved the modem literally 2 feet to the left into the doorway of the front door and got it to 100 and still nothing but a red light. Finally I put the satellite right underneath the cam--and it quickly and easily connected!
I went inside to add the camera on the website and it wanted to install new firmware which I thought was great news based on DaveEdmonds' comment in January. I thought maybe there's a fix? It finished the upgrade and began working perfectly. I unplugged the satellite to put it back where it belongs, and it continued to stream via the router for a few minutes and then failed, going back to a solid red light and a worthless camera guarding my house. And that's where I am.
DaveEdmonds
Mar 14, 2021Guide
I don't remember mentioning firmware to get my working. The only way my camera for my security system would work was to hardwire an extra router I g=had laying around to facilitate an additional access point that I used to connect both my camera, the alram panel and my garage door.
There are apparently many devices that don't play well with a mesh style network unfortunately, even icluding many home soundbars and other interior devices.
- betonaMar 14, 2021Apprentice
Naw, what I meant was, you'd posted that they put in a request to the camera developer about this issue, and I was hopeful that maybe the firmware upgrade I got on a brand-new cam might be the fix.
- DaveEdmondsMar 14, 2021Guide
Oh, got it. Yeah they never came back with anything or any information which sadly is typical of the alarm company we have.
Wait wait wait--I got it to connect. I saw a thread about a different security cam on Reddit in /r/orbi suggesting to set the 2.4Mhz Preamble Mode to Short:
Advanced tab > Advanced > Wireless Settings > Preamble Mode (top box for 2.4) set drop-down to Short Preamble.
I looked at the cam and it had a green light (!!). I was able to import it into alarm.com by searching on its MAC address and everything cranked right up. I don't know what that Preamble change means, but this was a complete surprise that it worked.
- DaveEdmondsMar 16, 2021Guide
Interesting the RBS850 at least that I have has no such option for that setting. EDIT, I finally found it it was to the right of the setting. I may try that. Thanks.
I also found this if interested:
Long Or Short Preamble: Pros And Cons - Internet Access Guide (internet-access-guide.com)
