Gitts
Apr 18, 2020Follower
ADD CAN YOU ADD RBS50 SATELLITE TO RBK752
I am looking at the Orbi AX4200 (RBK752) and was wondering if required in the future could I add an additional RBS50 satellite? Also what would the performance implication be as the RBS50 is wifi5?
CallPaul
Apr 18, 2020Apprentice
You can add a RBS50 to a RBK852 but only wired backhaul, it won't connect using wifi and it will only use a AC connection no AX. They were supposed to add the ability to wifi backhaul together but I don't think it's been implemented yet. I'd think the RBK752 would work the same way.
Jonnybunker
Jun 08, 2020Guide
I am also getting the RBK753 today, and currently have an RBR50, RBS50, and W30 Wallunit.
I was hoping to setup my 3 AX4200 throuhgout the house and use one of the RBS50 or W30 either in the garage or another location.
Would i only be able to connect the RBS50, by physically connecting it to a live ethernet port in the house? I have an extra port that i can do this, but not necessairly in the most convenient location.
Thanks!
- FURRYe38Jun 08, 2020Guru - Experienced User
Yes, RBS50s can be ethernet connected only to the Orbi AX system. Wireless is still not compatible at this time.
Jonnybunker wrote:I am also getting the RBK753 today, and currently have an RBR50, RBS50, and W30 Wallunit.
Thanks!
- JonnybunkerJun 08, 2020Guide
Thanks for the quick reply -
So i would want to keep the RBS50 to setup the Wired Backhaul, and then in hope that in a new firmware or update at somepoint, they may make the Wireless connectivity compatible between the AX and AC units at a later date, and if they did i could better place my system.
And the W30 unit, would be rendered useless until they do allow for wireless connectivity between the AX and AC units -
Okay, I think I will sell the RBR50 and the W30, appreciate the help and let me incorrect in any of my thinking.
I would keep the RBR50 for back up in case something happens or keep it and test the Orbi AX system out first before letting the RBR50 go.
