Gitts
Apr 18, 2020Follower
ADD CAN YOU ADD RBS50 SATELLITE TO RBK752
I am looking at the Orbi AX4200 (RBK752) and was wondering if required in the future could I add an additional RBS50 satellite? Also what would the performance implication be as the RBS50 is wifi5?
Jonnybunker
Jun 08, 2020Guide
I am also getting the RBK753 today, and currently have an RBR50, RBS50, and W30 Wallunit.
I was hoping to setup my 3 AX4200 throuhgout the house and use one of the RBS50 or W30 either in the garage or another location.
Would i only be able to connect the RBS50, by physically connecting it to a live ethernet port in the house? I have an extra port that i can do this, but not necessairly in the most convenient location.
Thanks!
Jun 08, 2020Guru - Experienced User
Yes, RBS50s can be ethernet connected only to the Orbi AX system. Wireless is still not compatible at this time.
Jonnybunker wrote:I am also getting the RBK753 today, and currently have an RBR50, RBS50, and W30 Wallunit.
Thanks!
- JonnybunkerJun 08, 2020Guide
Thanks for the quick reply -
So i would want to keep the RBS50 to setup the Wired Backhaul, and then in hope that in a new firmware or update at somepoint, they may make the Wireless connectivity compatible between the AX and AC units at a later date, and if they did i could better place my system.
And the W30 unit, would be rendered useless until they do allow for wireless connectivity between the AX and AC units -
Okay, I think I will sell the RBR50 and the W30, appreciate the help and let me incorrect in any of my thinking.
- FURRYe38Jun 08, 2020Guru - Experienced User
I would keep the RBR50 for back up in case something happens or keep it and test the Orbi AX system out first before letting the RBR50 go.
Okay thanks again, and I couldnt remmeber, does the RBR50 have the ability to be setup as a satellite , or does it only work as a main Router?
