plsee74
Jun 04, 2022Tutor
Add new satellite 752
Hi, INeed some advise why is the RBS 750 showing as out of sync on. The RBR 850, RBS 850 and RBS 750 are already on the latest firmware 4.6.8.2. I try to factory reset the RBS 750 but the result ...
- Jun 05, 2022
Thanks for the advise.
Jun 05, 2022Guru - Experienced User
Possible this switch maybe causing problems. I can't find the spec sheet on it however it may have "Green Ethernet" features which on some switch can cause problems on Orbi systems. I see this model switch is somewhat old as well. I recommend you try another swtich.
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Also be sure your using good quality LAN cables. CAT6 is recommended.
plsee74
Jun 05, 2022Tutor
