kieran1976
Feb 01, 2021Follower
add on satalite
hi all, i just bought a 3 pack orbi rbk353 and i need a fourth. and suggestions what i can add onto it
Feb 01, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What you currently have doesn't work to get you coverage?
