MarcB376
Aug 29, 2023Aspirant
Add On Satellite
I currently have an Orbital RBR350 Router with two RBS350 Satellites. Im now looking for something to go out into the rear garden and extend the signal that little bit better. I have looked and ...
CrimpOn
Aug 29, 2023Guru - Experienced User
Netgear products can be difficult to find. Amazon UK shows only one RBS350:
I found one on eBay UK, but is was an entire set and was in the 'bid' process, with no "Buy Now" price quoted.
If placed against an outside wall, 50% of the radio signal will broadcast outside. (In a window might be better considering how much brick is used in UK construction.)
Extending WiFi coverage involves one major consideration: Is seamless roaming a "deal breaker"? The significant difference between Orbi "satellites" and ordinary "WiFi Extenders" (from any brand, including Netgear) is that satellites fully implement the 802.11 standards that allow devices to switch from one WiFi access point to another by themselves. WiFi Extenders create a separate WiFi network. Even if this network has WiFi credentials identical to the Orbi network (SSID/password), it is a separate network. A device connected to the Orbi will gradually lose signal strength and quality as it gets farther from the Orbi, but will "hold onto" the Orbi until it finally just gives up and then begins to look around for a WiFi system that it recognizes. "Aha. Here's one!" If simply walking out into the garden caused the Orbi signal to drop to the point that devices gave up on the Orbi almost instantly, then the user would probably notice nothing. Otherwise, the user would complain, "why is the WiFi so SLOW???" The solution is to turn WiFi off and back on again (5 seconds).
Mobile devices are is why mesh systems are so popular.
On the other hand, if the goal is to provide WiFi to speakers, security cameras, etc. in the garden (devices that never move), then any old WiFi extender is a good solution. There are even WiFi extenders designed to mount outdoors (weather resistant).
- MarcB376Sep 14, 2023Aspirant
So as I'm still looking to add extra coverage to my network would this product be any good ? (image attached below)
As i say i am running a Wi-Fi 6 Mesh system RBK353 AX1800.
- CrimpOnSep 14, 2023Guru - Experienced User
My answer is, "probably".
- This product is clearly intended to connect to the Nighthawk line of WiFi routers.
using both the Orbi and Nightawk apps could be annoying. - That talk of "smart roaming" is not likely to apply to non-Nighthawk products.
- It is an indoor product designed to plug into a wall outlet, so window mounting would be awkward.
I would definitely purchase from a vendor with a generous return policy.
- MarcB376Sep 17, 2023Aspirant
I fail to see where the product is listed to be used with a NIGHTHAWK line.
I have looked and looked, All im trying to do is extend my wifi to down the bottom of the garden to a summer house.Like I say I have tried on a number of times to buy the Wifi Extender RBS50Y which is the outdoor one and now discontinued and no longer made.
I have then tried to buy an add-on RBS350 Satellite AX1800 100-EUS with no joy and they are all refurbished from auction sites.Im looking at the AX1600 plug in Mesh extender to get my wifi that little further.
Can anyone else recommend a wifi booster for distance that matches with my RBR350 set up ??
