russellreece
May 07, 2024Aspirant
add rbr750 satellite to rbr850 router
Hi, Can I add a rbr750 satellite to existing rbr850 router?
- May 07, 2024
This Netgear web site states that a RBS750 ("S" for satellite) is compatible with the RBR850 router:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
RBR750 is the product number for a "router", which cannot function as a satellite. Some manufacturers designed their WiFi systems where units are identical and can take on either role. Netgear did not.
CrimpOn
May 07, 2024Guru - Experienced User
- russellreeceMay 07, 2024Aspirant
Thank you! Yes, meant an RBS not RBR! Thank you for the reply!
