SkywalkerPD
Jun 25, 2024Apprentice
Add reservation error
Trying to add a reservation for my setup box. I get the following error when clicking apply.. The reservation itself I selected from the selection list. So it has to be correct. Any ...
- Jul 01, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jun 25, 2024Guru - Experienced User
Do you have this device on the Guest Network? You can't reserve IPs for the Guest Network. Can only reserve IPs on the main LAN under 192.168.1.x
