SkywalkerPD
Jun 25, 2024Apprentice
Add reservation error
Trying to add a reservation for my setup box. I get the following error when clicking apply.. The reservation itself I selected from the selection list. So it has to be correct. Any ...
- Jul 01, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
SkywalkerPD
Jun 30, 2024Apprentice
Again thank you for thinking with me.
To answer your questions.
With the primary network changed to 192.168.1.x
The reservations automaticly changed from 192:168.2.x to 192.168.1.x So the list was still there
DHCP scope automaticly change to 192.168.1.x
The system was rebooted
All devices with 192.168.2.x connected to the primary network as I disabled GN.
It looked like there was a 'secret' range still active and I couldn't get rid off it.
At that point I decided to do a compleet factory reset and start over from the start. For now that did the trick and all devices are now getting 192.168.1.x addresses
Jul 01, 2024Guru - Experienced User
Enjoy. 📡
