nsapcor
Jul 28, 2021Tutor
add third satellite to RBR850
My current setup is RBR850 router with two RBS850 satellites, one wireless and the other ethernet. I want to add a third satellite via ethernet but the port currently is wired to a desktop. Is a solu...
- Jul 28, 2021
Ok so you have a wall LAN jack that comes from the down stairs RBR correct?
If so, then you can place a RBS at this location and connect the wall jack to the RBS here. Then use the free additional ports on the back of the RBS to connect other wired devices to the RBS...Or you can place a Gb LAN switch as this wall jack and then connect the PC and RBS to this all jack.
https://www.downloads.netgear.com/files/GDC/datasheet/en/GS105v3-GS108v3.pdf
Jul 28, 2021Guru - Experienced User
"I want to add a third satellite via ethernet but the port currently is wired to a desktop." What port are you referring too?
- nsapcorJul 28, 2021Tutor
THe proposed location of the new satellite is an upstairs room with an ethernet plug (rather than port) hardwired from the downstairs Orbi router. That plug in turn is currently hardwired to the desktop that I want to retain. I want to hardwire the new satellite from that same plug. Hence the need for two lines via a splitter, switch or some other device.
- FURRYe38Jul 28, 2021Guru - Experienced User
Thanks
