nitehawk747
Feb 23, 2023Tutor
Adding a access point to my AX6000 Tri-band Mesh Wi-Fi Router with one satellite
My house is a large "U" shape, with lots of wood and items on the walls. I have the Orbi AX6000 Tri-band Mesh Wi-Fi Router with one satellite. I'm looking to use my old nighthawk AX8 Wi-Fi 6 Exten...
nitehawk747
Feb 24, 2023Tutor
So setting it up on a different channel and a different SSID, means this will work, but not as a continuous mesh . Guessing AP can not be part of a Mesh system. If this works , I need to decide to run another AP in the far corner of the house for the internet and outside cameras. Can a AP be setup not to broadcast?
Feb 24, 2023Guru - Experienced User
Correct, it doesn't integrate with the mesh so you don't want it to have the same ssid or your roaming will tend to be "sticky" and not roam very efficiently. You can set it not to broadcast but then whats the point of it?
