the_witho
May 04, 2022Aspirant
Adding a new Orbi Satellite RBS850
Hi all, Apologies if this has been answered already somewhere but having been struggling to pair a new satellite with existing RBK853 mesh system. I have followed the instructions to pair with Or...
- May 04, 2022
Try hardwiring the new satellite into the router and syncing it.
After you sync it, then try disconnecting it and see if it works.
May 04, 2022Guru - Experienced User
Can you connect the RBS to the back of the RBR via ethernet and see if it will connect and get a IP address that you can input into a browser and log into the RBS web page and update the RBS FW? I presume the FW on the RBS is not in sync with your current systems FW which it needs to be.
