brentoss99
Jun 20, 2022Aspirant
adding a RBR350 as a third satellite
I recently brought a Orbi AX1800 WiFi 6 Dual-band Mesh Router with 2 satellites for my home. I've found a used RBR350 could i use this as an additional satellite to extend the reach of my network?
AX1800 is a sped, not a model. what actual model did you buy?
- brentoss99Aspirant
hi the model i brought was a Orbi 6 RBR350 1x Router & 2 satellites do you need any further details?
For the orbi's, the RBR's are the router and can't be used as a satellite. If you had a used RBS, you'd be fine.
