bamer02's avatar
bamer02
Adding a wifi 6e router to an existing rbr750/rbs750 mesh system
Hello,
Currently have Spectrum 1gb with a CM2000 modem and rbr750/rbs750 mesh (router mode). Everything is working fine. However, I added a newly built gaming computer with wifi 6e capabilities that I want to take advantage of.
Would like to keep the same system since there are multiple home devices connected (40+).
Is it possible to connect a wifi 6e router directly to one of the rbr750 ports?
Thank you in advance!
  • FURRYe38's avatar
    Yes. I would recommend this 2ndary 6E router be configured for AP mode.
    • bamer02's avatar
      bamer02
      Thank you for the quick response! I will go ahead and buy the 6e router (still trying to figure out which one).
