XTREME-IT
Jan 27, 2022Aspirant
Adding an outdoor Netgear access point to work with ORBI AXE 11000
I have a new Orbi AXE11000 and want to add another outdoor netgear access point. Looking for the model that will synchronize or be managed by the controller with the AXE11000 so I don't have to add a...
Jan 27, 2022Guru - Experienced User
Only outdoor satellite that may work is the RBS50Y which would need to be in Extender mode (FW) for it to work with the Orbi 9 series.
I don't have a RBSY so I can't confirm to weather it actually works with a Orbi 9 series. The RBSY works in Extender mode with Orbi 8 series from what others have posted so I can only presume it may work with the 9 series.
- XTREME-ITJan 27, 2022Aspirant
Thanks for the info. I will try that out.
Rick
- FURRYe38Jan 27, 2022Guru - Experienced User
đ
- Turns2Feb 09, 2022Tutor
I'm also considering the AXE11000, and I currently have a RBS50Y which has worked excellent for me.
I see the instructions where this can be used to extend a non-Orbi system, but are we 100% certain it will work with the AXE11000? The FAQs around this topic are confusing.
