netvista
Oct 25, 2020Follower
Adding an Outdoor Orbi Satellite to a WiFi 6 System
I just installed an Orbi AX4200 (RBK753S) and would like to add an outdoor satellite. Can I use the RBS50Yv2 — High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite? Or do I need t...
Oct 25, 2020Guru - Experienced User
If you load the Extender mode FW on the RBSY, then yes you can. It won't work if Orbi mode FW is loaded.
