netvista
Oct 25, 2020Follower
Adding an Outdoor Orbi Satellite to a WiFi 6 System
I just installed an Orbi AX4200 (RBK753S) and would like to add an outdoor satellite. Can I use the RBS50Yv2 — High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite? Or do I need t...
CalvinL
Apr 10, 2021Initiate
I am using the Orbi WiFi 6 System (RBK752) AX4200 Tri-band 2 pack at home. Now, I consider to purchase Add-on Orbi Outdoor Satellite (RBS50Yv2) AC3000.
However this outdoor product is AC series which is diffent from AX. Would it be degraded the home network performance? Are they compatiable?
In the Netgear website, Orbi Outdoor Satellite RBS50y and RBS50yv2 is only for AC3000.
Would the Netgear release a newer outdoor model for AX series in near future?
Apr 11, 2021Guru - Experienced User
If you load the Extender mode FW on the RBSY, then yes you can. It won't work if Orbi mode FW is loaded.
NG doesn't post any information on if or when new products will be forth coming.
CalvinL wrote:I am using the Orbi WiFi 6 System (RBK752) AX4200 Tri-band 2 pack at home. Now, I consider to purchase Add-on Orbi Outdoor Satellite (RBS50Yv2) AC3000.
However this outdoor product is AC series which is diffent from AX. Would it be degraded the home network performance? Are they compatiable?In the Netgear website, Orbi Outdoor Satellite RBS50y and RBS50yv2 is only for AC3000.
