WN_143
Feb 23, 2023Guide
Adding Nighthawk RAX80 as Access Point to Orbi 960 Setup
I recently purchased an Orbi 960 3-pack and have it setup. Quite pleased with its performance and stability. That said, I have a remote lower level where the I'd like to add an Access Point for imp...
WN_143
Feb 23, 2023Guide
The house size (although very large) is probably not the main issue. My need is to extend the coverage to include WiFi to a far corner of the property. I can get ethernet cabling into place and then setup a unique channel/SSID via the Access Point.
By the way... a most interesting video that you included...
Feb 24, 2023Guru - Experienced User
That should work pretty solid then for what you're trying to accomplish.
