EGS123
May 19, 2020Follower
Adding Non-AX6000 Satellite to Orbi WiFi 6 AX6000 System (RBK852)
I currently have the Orbi WiFi 6 System AX6000 (RBK852) with one router and one satellite. I'd like to add another sateliite, but they are currently unavailable (RBS850). Is it possible to buy a sate...
May 20, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. They can be placed farther out as well. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
I would recommend waiting for the 850 series RBS to become avialable.
EGS123 wrote:I currently have the Orbi WiFi 6 System AX6000 (RBK852) with one router and one satellite. I'd like to add another sateliite, but they are currently unavailable (RBS850). Is it possible to buy a satellite from another Orbi system (for example, the RBS50) and add it to my current AX6000 mesh system or will that not work? Any recommendations?
