Invisithorne
Sep 23, 2020Follower
Adding Orbi Voice to AX4200 / RBK753S Mesh Network
I currently have a a Netgear AX4200 / RBK753S Mesh Network. I was thinking of adding the Orbi Voice Satellite to my network in order to improve coverage in my basement (and add a speaker at the same ...
- Sep 23, 2020
SInce Orbi AC RBS are not wirelessly compatible with Orbi AX, you can connect the RBS40v to the Orbi AX via ethernet and use it that way. Speed would not be a factor in this configuration.
Sep 23, 2020Guru - Experienced User
