kat328
Jul 20, 2020Aspirant
Adding outdoor satellite
I need to know if there is an outdoor satellite that can work with Orbi AX4200 (RBK753s)? If yes, what is the model number? Will it easily sink with the system?
Jul 20, 2020Guru - Experienced User
We've been told by NG that the RBS50Y outdoor satellite will work with Orbi AX if you install the extender mode FW on the RBSY.
windansea
Jul 26, 2020Tutor
Hello!
A few messages on this board suggest that NG will release firmware so the RBS50Y can connect to Orbi WiFi 6 routers (like the RBR850) in Orbi mode. Does anyone have an update on this?
- FURRYe38Jul 26, 2020Guru - Experienced User
Nothing known. NG won't or may not say or annouce anything. Best to keep an eye on NGs download site.
