irish36
Jun 22, 2021Tutor
Adding RBR750 to a Centurylink C3000z modem/roter
My zycel c3000z modem/router is supplied by my ISP (Centurylink). I'm trying to add my RBR750 as the router and wireless component. Where do I plug in the RBR750 to the zycel to make it take ...
- Jun 28, 2021
Great on the laptop! Macs and the iPad should be able within the WiFi software "Renew" the lease on the connection that should clear out the old set up and grab the latest. Or "forget" the connection and relink to the WiFi. That's what I have to do every so often.
Well at least you got an education?!
Cheers ! đ»
Jun 22, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
You would plug the RBRs Yellow WAN port using a LAN cable into one of the modems open LAN ports in back...Refer to any Modem user manual documentation for information regarding this or contact the ISP for additional help as well.
