irish36
Jun 22, 2021Tutor
Adding RBR750 to a Centurylink C3000z modem/roter
My zycel c3000z modem/router is supplied by my ISP (Centurylink). I'm trying to add my RBR750 as the router and wireless component. Where do I plug in the RBR750 to the zycel to make it take ...
- Jun 28, 2021
Great on the laptop! Macs and the iPad should be able within the WiFi software "Renew" the lease on the connection that should clear out the old set up and grab the latest. Or "forget" the connection and relink to the WiFi. That's what I have to do every so often.
Well at least you got an education?!
Cheers ! đ»
irish36
Jun 22, 2021Tutor
Thanks for the quick reply FarmerBob1,
The first step - putting the zycel in bridge mode - is the one giving me trouble. When I go into the Broadband settings on the Zycel there are multiple settng to be done and I don't recognize any as related to bridging. Here are the settings I see-
1. Select the WAN connection type.
2. Select the line mode.
3. Select the transport mode.
4. Set the MTU value.
5. Enter the VLAN parameters.
There are parameters for each selection but it won't let me cut and paste them. I hope that's enougth info.
irish36
Jun 22, 2021Tutor
Also I forgpot to mention I have DSL
