irish36
Jun 22, 2021Tutor
Adding RBR750 to a Centurylink C3000z modem/roter
My zycel c3000z modem/router is supplied by my ISP (Centurylink). I'm trying to add my RBR750 as the router and wireless component. Where do I plug in the RBR750 to the zycel to make it take ...
- Jun 28, 2021
Great on the laptop! Macs and the iPad should be able within the WiFi software "Renew" the lease on the connection that should clear out the old set up and grab the latest. Or "forget" the connection and relink to the WiFi. That's what I have to do every so often.
Well at least you got an education?!
Cheers ! đ»
irish36
Jun 26, 2021Tutor
Hello FarmerBob1,
Thanks for your advice
Itseemed tome that my laptopwasstill looking for the old networks that were on the C3000Z, so I decided to uninstall my wi-fi deviceand reinstall it. That did the trick. After that I was able to selecet the network name and attach to the network. The laptopseems to do all the networkfunctions id did before I enstalled the ORBI.
Now, on to getting the iPad to connect.
Thanks again for your help.
FarmerBob1
Jun 28, 2021Luminary
Cheers ! đ»
- irish36Jun 28, 2021Tutor
Thanks so much for your help Farmerbob1. Now I have a workable system.
