Jumpster
May 23, 2022Follower
Adding RBS850 Satellite slows system to a crawl
I have a (very) long house with the internet access at one end, so I need to place the RBR850 router at that location. My home office is at the opposite side of the house. I have three satellites (...
May 24, 2022Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 and RBS to RBS to begin with depending upon building materials when wirelessly connected.
Also how the RBS are turned on can effect how they connect. Turning on the RBS one at a time and let them sync fully can get the RBS to daisy chain correctly.
Can also try turning down the transmit power on the RBR and see if this helps. Try 50%.
Under Advanced Tab/Advanced Settings/Wireless Settings
