Teddy123TutorSep 02, 2020Adding three satellites to AX6000 RBK 853 Hello, Is it possible to add three addtional satellites to an AX6000 system that comes with two satellites? Many thanks Teddy123
Teddy123Tutor to KKSigsSep 02, 2020Many thanks and for such a rapid resonse!FURRYe38Guru - Experienced User to Teddy123Sep 02, 2020From what others have posted, NG seems to only officially support 4 RBS total wirelessly. I presume if you wired the RBS, they should work in that configuration. Let us now if you get them all connected. Teddy123
