klp110
Sep 06, 2020Follower
Adding Z wave with WPS
I am having difficulty add Jalsco (Honeywell-zw3104) Z wave dimmer to my network using the WPS to my Orbi RBK853 router/network. I have replaced a previous network and everything worked just fine. A...
CrimpOn
Sep 06, 2020Guru - Experienced User
klp110 wrote:I am having difficulty add Jalsco (Honeywell-zw3104) Z wave dimmer to my network using the WPS to my Orbi RBK853 router/network. I have replaced a previous network and everything worked just fine. Any suggestions?
The previous network appears to be the key question. There are some residential WiFi routers that include Z-Wave and Zigbee. The Orbi does not.
So, exactly which router was installed when "everything worked"?
