Sevo123
Oct 25, 2019Apprentice
Additional satellites
Hi I want to purchase the new Orbi AX unit but I need help. Where can I purchase more Satellites from? If I possibly purchase 2 units can I use the additional router as a satellite?
Oct 25, 2019Guru - Experienced User
No additional satellites available separately currently.
Chuck_M
Nov 03, 2019Mentor
I purchased the AX a few days ago and installed this am.
Was pleasantly surprised to see that the RBS50 sattelites I have work just fine on the Orbi AX.
In fact, I have one RBS850 sattelite, one RBS50 satellite and my original RBR50 in AP mode hard wired back to the RBR850.
Smooth as silk.
- DoctorANov 03, 2019Luminary
I wonder If an old NG non mesh router will work in AP mode. I am horder and kept WNDR4500
Chuck_M wrote:I purchased the AX a few days ago and installed this am.
Smooth as silk.
- FURRYe38Nov 03, 2019Guru - Experienced User
You can. Just needs to be on far separate wifi channels away from what the Orbi is using. This can add to the wifi noise however.
- DoctorANov 06, 2019Luminary
So RBR50 in AP mode becomes identical to RBS50? My neighbor has an extra RBR50 he is not using.
Smooth as silk.
- flickhuckFeb 22, 2020Aspirant
How did you get the RBS50s to connect to the RBR850?
Smooth as silk.
