Sevo123
Oct 25, 2019Apprentice
Additional satellites
Hi I want to purchase the new Orbi AX unit but I need help. Where can I purchase more Satellites from? If I possibly purchase 2 units can I use the additional router as a satellite?
Sevo123
Nov 05, 2019Apprentice
Not going to purchase the AX unit until they release the satellites to purchase separately .
Nov 05, 2019Guru - Experienced User
How big is your home? Sq Ft? Mines 5000Sq Ft, no issues with WiFi coverage with just the RBR and 1 RBS wirelessly connected. Even with the RBS in the basement and RBR on 2nd story level. Good wifi coverage and operation. Something to try as suggested. If you don't like it, then return it.
