gobuffs21
Mar 22, 2022Aspirant
Admin Login Orbi RBR750
Hello, trying to log into the admin settings and I keep getting prompted to reset my password. I go through the steps of entering serial number, answering security questions, entering new password, ...
gobuffs21
Mar 23, 2022Aspirant
Thank you! That worked! I would add to also write down the name of your network and after reset use the same name and password. Otherwise you need log back into all your devices. I couldn’t remember the exact name of my network so that caused extra work. Anyway, thanks again
Mar 23, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
