bmwr75
Dec 14, 2021Star
Adtran SDX 621 fiber modem and Netgear Orbi RBR750 won't communicate
Recently purchased the Netgear Orbi RBK753S High-Performance Whole Home Mesh WiFi System. Cannot get it to work when connected directly via ethernet to my Adtran SDX 621 fiber modem. If I con...
- Dec 14, 2021
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axBe sure to restart your network in this sequence:
Turn off and unplug modem.
Turn on computers and rest of network.
Thank you
Retsehc
Dec 16, 2021Tutor
Your ONT This should be your device. If not, search for it on the site.
You have a cable that enters your property (drop cable). The drop cable provides the optical signal which the modem (Optical Network Terminal) will transform into an electrical signal and pass to the router (via the Ethernet cable).
Has the service worked prior to inserting the RBR750?
You can always open a case with Adtran: openasupportcase
