bmwr75
Dec 14, 2021Star
Adtran SDX 621 fiber modem and Netgear Orbi RBR750 won't communicate
Recently purchased the Netgear Orbi RBK753S High-Performance Whole Home Mesh WiFi System. Cannot get it to work when connected directly via ethernet to my Adtran SDX 621 fiber modem. If I con...
- Dec 14, 2021
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axBe sure to restart your network in this sequence:
Turn off and unplug modem.
Turn on computers and rest of network.
Thank you
CrimpOn
Dec 16, 2021Guru - Experienced User
Retsehc wrote:
Has the service worked prior to inserting the RBR750?
You can always open a case with Adtran: openasupportcase
See the original post. The goal is to remove the ISP router in order to forward ports to a NAS. The RBR750 worked, but could not forward ports because of the Double NAT situation. Would be interesting to see if Adtran responds to a non-customer. My guess is that the ISP is the actual 'customer' who could file a support case. Certainly can't hurt to try..
bmwr75
Dec 17, 2021Star
My ISP did an update on their fiber modem ONT and the Netgear Orbi started working as it should after a restart.
- michaelkenwardDec 17, 2021Guru - Experienced User
Result! I admire your persevance. Thanks for reporting back.
