roxyroo
Nov 08, 2021Tutor
Advice needed on setting up Orbi 853
My new Orbi 853 system will be arriving shortly and I am looking for advice on how to set it up. I will be connecting this to my ATT Gateway on bi-directional Gigabit Fiber. Do I just turn off the ...
- Nov 08, 2021
It can if you have wired devices connected to the RBS.
If you want to use the Orbi as your main host router, you'll need to connect everything to the Orbi router. if you have more than 4 LAN wired devices, then you can add a Gb switch to the back of the RBR for additional LAN ports. NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
roxyroo
Nov 08, 2021Tutor
Thanks. Does any of this impact wired ethernet connections? It I dissable NAT on the ATT router would I still be able to use the built-in 4 port switch on it or would I have to feed everything that is wired off the Orbi with a separate wired switch plugged into it?
Nov 08, 2021Guru - Experienced User
