FrogMan_SMC7
Jul 13, 2021Follower
Advnaced settings for Orbi rbr 850
Can anyone help me with provinding the best advance settings as of Today July 14th, 2021. My info: 1) Orbi RBR 850 + 1 Sat RBS850: 2) House 2200sqft. Location is great I believe 3) Need help wit...
Jul 14, 2021Guru - Experienced User
What is the distance between the router and satellite(s)📡? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Contact your ISP about IPv6. Some ISP don't support native IPv6.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-port-forwarding-doesn-t-work/td-p/1984296/jump-to/first-unread-message
