ssohata
Mar 06, 2021Aspirant
After 6 mos of no problems Orbi contantly offline usually early morning.
After 6+ mos of no problems my Orbi RBK753 is constantly offline and I am rebooting it 1-2 a week. Is that normal? My modem is a Netgear CM1200 that I bought directly from Netgear at the same time...
Mar 06, 2021Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What is the distance between the router and satellite(s)?
