atiq020
Nov 25, 2022Aspirant
After firwmare updare RBKE960
I Upgrade my orbi rbke960 router firwmare to the latest but unfortunatly both satellites are not upgarded Now my router not find any sattellites i tried to downgrade firmware manually but its fail....
- Nov 25, 2022
How did you try to downgrade the RBR?
Using a wired PC and web browser and downgrading the RBR using the downloaded FW file from prior version should have worked long enough for you to get the RBS re-connected, then manually update them, then the RBR lastly.
NOW its router latest firmware but both rbks960 not showing or adding i unlpug all but not resolved. also i connect one of my salttelie directly eathernet cable with router and try to add but still not find
please Advise APPRECIATE
Thanks
michaelkenward
Nov 25, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
