atiq020
Nov 25, 2022Aspirant
After firwmare updare RBKE960
I Upgrade my orbi rbke960 router firwmare to the latest but unfortunatly both satellites are not upgarded Now my router not find any sattellites i tried to downgrade firmware manually but its fail....
- Nov 25, 2022
How did you try to downgrade the RBR?
Using a wired PC and web browser and downgrading the RBR using the downloaded FW file from prior version should have worked long enough for you to get the RBS re-connected, then manually update them, then the RBR lastly.
NOW its router latest firmware but both rbks960 not showing or adding i unlpug all but not resolved. also i connect one of my salttelie directly eathernet cable with router and try to add but still not find
please Advise APPRECIATE
Thanks
atiq020
Thanks
- KevinLiTNov 29, 2022NETGEAR Moderator
Hello atiq020,
Welcome to the NETGEAR Community!
I understand that you are not able to SYNC your RBRE960 to your satellites due to a firmware mismatch. Please connect your PC to your satellite and then manually upgrade your satellites.
Please navigate to the link below for instructions on manually upgrading your satellite:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Please keep me informed of the progress of this issue!
Best,
Kevin
Community Team
- atiq020Dec 10, 2022Aspirant
Thankyou i done as per your instruction Now all 2 sat are working fine and backhaul are GOOD Now my next question is in future if i found new firmware how do i without this all mess? normally i just check on login to router and if any available i Upgrade
But i checked all of you advised Download for satelites FIRST but when i click its starts checking from router and then satellites
IF FIRST SATELITE then Router so netgear should fixed this ? not everyone goes to forums or googles we just check and press and go pleaes clear Many thanks
- FURRYe38Dec 10, 2022Guru - Experienced User
The check only performs a check to see whats out there against what is on your system. This is only a check, no FW is being applied at this point. If you do use the Auto Update or FW check then select the Update ALL button, the update system should then apply any FW updates to the RBS first then the RBR lastly. At least theoretically.
I recommend that you disable the FW auto update feature on the RBR. Then check here in the forums or on NGs download site for any updates to your Orbi system. Then manaully update your RBS first then the RBR lastly.
