atiq020
Nov 25, 2022Aspirant
After firwmare updare RBKE960
I Upgrade my orbi rbke960 router firwmare to the latest but unfortunatly both satellites are not upgarded Now my router not find any sattellites i tried to downgrade firmware manually but its fail....
- Nov 25, 2022
How did you try to downgrade the RBR?
Using a wired PC and web browser and downgrading the RBR using the downloaded FW file from prior version should have worked long enough for you to get the RBS re-connected, then manually update them, then the RBR lastly.
NOW its router latest firmware but both rbks960 not showing or adding i unlpug all but not resolved. also i connect one of my salttelie directly eathernet cable with router and try to add but still not find
please Advise APPRECIATE
Thanks
Nov 25, 2022Guru - Experienced User
Thanks
