Crazy_Canuck
Oct 21, 2024Aspirant
After Power Cycling RBR / RBS 850 - Cannot Connect To Main Wifi - Only To Guest Wifi
Hello - I have a very frustrating issue where, after rebooting / power cycling my RBR850 and my RBS850s, nothing can connect to the main Wi-Fi - only to the guest Wi-Fi. I have looked all over the we...
Crazy_Canuck
Thanks for the response - I am going to downstage to .21 and see if that resolves the issue. For the other questions - around 2,800 sqft, all satellites are around 30ft and yes I have did a factory reset last weekend.
Oct 21, 2024Guru - Experienced User
After you get the system downgraded, might try turning OFF one RBS temporarily and observe.
