Crazy_Canuck
Oct 21, 2024Aspirant
After Power Cycling RBR / RBS 850 - Cannot Connect To Main Wifi - Only To Guest Wifi
Hello - I have a very frustrating issue where, after rebooting / power cycling my RBR850 and my RBS850s, nothing can connect to the main Wi-Fi - only to the guest Wi-Fi. I have looked all over the we...
Crazy_Canuck
Oct 22, 2024Aspirant
Thanks for that recommendation. I wasn’t sure if the .31 cfg would work or not so thanks for saving the the time and effort.
Oct 22, 2024Guru - Experienced User
When and if you downgrade back to v.21, be sure to disable auto update check, or the system may re-update back to v.31.
- Crazy_CanuckOct 22, 2024Aspirant
Besides getting rid of the connection issues (hopefully) by going to v .21 - is there anything that I am losing beyond security improvements by downgrading from v .31?
- FURRYe38Oct 22, 2024Guru - Experienced User
No.
