thelopi
Sep 21, 2022Aspirant
After power outage, Can't connect to Wifi unless I change the internal IP address.
I just set up an Orbi 963 with 2 satellites. For some reason, it would not let me use my old router's SSID so I had to change to a new SSID and reconnect my 90+ devices. Frustrating but worth it fo...
- Oct 05, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
thelopi wrote:
OMG! After weeks of trial and error, I found the problem. It was the Motorola Router that needed to be factory reset. Now, my TriWAN system is up and running. Thanks for all of your suggestions. I learned a lot. Most importantly the power of a factory reset.
michaelkenward
Sep 21, 2022Guru - Experienced User
thelopi wrote:
I have the latest Firmware on all the devices. I have a Motorola MB8611 3.1 multi gig cable modem using comcast, a TP-Link ER7206 Multi-Wan Gigabite VPN router to allow for Dual Wan setup since the Orbi does not have a dual wan connection.
A few clues in that long that slab of uninterrupted text. (I have a poor attention span.)
You have two routers. The TP-Link ER7206, alongside an unknown (to us) Orbi device? Orbi 963 isn't a model number that I can find.
Is the Orbi in wireless access point (AP) mode?
If not, two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
CrimpOn
I believe the product may be this one:
https://www.netgear.com/support/product/RBKE963.aspx
Agree that a more typical configuration would be to put the Orbi into Access Point (AP) mode so that the TP-Link handles all IP assignments in addition to managing the two Wide Area Networks (Comcast and ATT/Starlink?)
I can think of no reason why the Orbi WiFi could not have whatever SSID the user wants it to have. (Seriously, there is nothing to stop a person from setting up a dozen WiFi systems all using the same SSID/password. Would be a tangled mess in terms of figuring out which system each WiFi device would decide to connect to, but that would simply be a consequence of doing something goofy.)
There are often issues when enabling Guest (and what about IoT?) WiFi SSIDs when the Orbi is in AP mode. In earlier Orbi products, AP mode disabled DHCP on the router, which simply passed all DHCP requests up to the primary router (In this case the TP-Link). The 960 product is relatively new, and I have no personal knowledge of "what happens" when it is in AP mode.
I have fantasized about having redundant (multi-WAN) internet, and this post illustrates how complicated it might become.
In addition to the TP-Link and Orbi routers, I wonder what equipment is handling the Comcast and (Starlink - or Starling?) WAN connections. Are they also routers?
