thelopi's avatar
thelopi
After power outage, Can't connect to Wifi unless I change the internal IP address.
I just set up an Orbi 963 with 2 satellites.  For some reason, it would not let me use my old router's SSID so I had to change to a new SSID and reconnect my 90+ devices.  Frustrating but worth it fo...
  • FURRYe38's avatar
    Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
    Enjoy. 📡
    thelopi wrote:
    OMG! After weeks of trial and error, I found the problem. It was the Motorola Router that needed to be factory reset. Now, my TriWAN system is up and running. Thanks for all of your suggestions. I learned a lot. Most importantly the power of a factory reset.
