_Tony_Stark_
Jun 09, 2022Aspirant
After receiving update and working for a bit, router is now useless hours later.
After receiving update and working for a bit, router is now useless hours later. Magenta ring of death since before work early this AM. Got home, same story and apparently factory reset won't work, s...
_Tony_Stark_
Jun 10, 2022Aspirant
Im using the Orbi AX4200 RBK753 series with two satellites.
Everything was fine until I asked for the update to be pushed that would allow app to login in. Seemed to work for a few hours. Now, I have no Wi-Fi and can't login in to even see firmware version.
I'm on Comcast Xfinity with their xb1 advanced gateway(Arris brand) in bridge mode.
Nothing has been changed since I first set this up 2 years ago. Everything was fine until this update.
I checked modem/gateway just to make sure, connecting ethernet from modem to pc and it worked, so it's the Orbi. I've done the reset process many times, no go, still magenta ring. New setup doesn't work either. This is killing me rn.
Jun 10, 2022Guru - Experienced User
- _Tony_Stark_Jun 10, 2022AspirantAs I said, I can't say right now because I'm unable to login in to the device and have no network now.
Whatever the push update was to allow the restoration of remote access was the last update, prior to that, it was current, say no updates.- FURRYe38Jun 10, 2022Guru - Experienced User
Ok, so disconnect the RBR from the ISP modem. Connect only one PC to the back of the RBR.
Press the reset button in back of the RBR for 20 seconds then release.
Using MS Edge or Firefox browser and after the front LED pulsates WHITE, try accessing HTTP and 192.168.1.1. You should see a Orbi app display page and at the very bottom, there is link to select, Don't have this app. Should start the setup wizard here.
- _Tony_Stark_Jun 10, 2022AspirantWill try when home from work later on and I'll update you.
Thank you for that.
